Arc welding machine circuit using 25kHz thyristor inverter
Source: InternetPublisher:清宁时光 Keywords: arc welding machine thyristor electromechanical Updated: 2021/02/09
For an arc welding machine using 25kHz high frequency and thyristor inverter , the transformer can be smaller. The circuit is shown in Figure 9-14.
The no-load output voltage of the machine is 45V DC, 90V (peak), and the short-circuit current is 125A DC.
The circuit consists of five parts: power supply part (composed of diodes VD16~VD2, filter capacitor C7, etc.), inverter
part (composed of diodes VDi~VD4, thyristor Vl-V4, resistor Ri-R4, capacitor CL and inductor Li, etc. Composed), trigger
circuit (composed of pulse transformers TMi, TMz and related resistor-capacitive components, diodes, voltage regulator tubes, etc.), output
part (composed of transformer T and diodes VD22~VD25, etc.) and arc suppression circuit (composed of It is composed of bidirectional thyristor V5, thyristor
V5, voltage regulator VS3, diode VD?,6, capacitor C8, resistor R14~Rl7, etc.).
- The basic principles of power supply design. What are the key components of a power supply?
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Principles and precautions of active discharge circuit
- LNK304 non-isolated LED light string driver circuit
- A simple positive and negative power supply circuit
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- Power supply circuit that can reduce LM317 ripple
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Battery charger charging status display circuit
- Light controlled automatic curtain circuit
- Transistor controlled rectifier circuit a
- Water dispenser (Aucma) temperature detection control circuit
- Voltage controlled sawtooth oscillatora
- Fast spot welding machine circuit using thyristor switch
- ZXG-500 DC arc welding machine circuit
- AR-300 DC arc welding machine circuit
- BX2 series AC arc welding machine circuit d
- Thyristor cut-off delay circuit 6
