The fourth long-delay circuit using integrated circuits
Source: InternetPublisher:常思一二 Keywords: Delay circuit integrated circuit potentiometer Updated: 2020/02/22
It also uses the CD4060 integrated circuit . The circuit is similar to the picture. Delay time
t=18842 (RP+R4)C3 (s), adjust the potentiometer RP to change the delay time. According to the component parameters shown in the figure , the delay time
can be freely set within 90s~1.4h.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Tutorial on making your own remote-controlled robotic arm
- Build a glove-controlled robotic arm
- How to build a simple tachometer using an infrared reflectance sensor
- DIY an electromagnetic levitation device
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- How to set up a cheap beam break sensor control distance scene using a reflector
- One-way rotation circuit of motor controlled by contactor
- An experimental model of an infrared radio alarm
- "Watchdog" anti-theft alarm circuit
- 13 examples of electric drag control circuit diagram
- Rural fish farming control circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- fire smoke control circuit
- Thyristor cut-off delay circuit 6
- One of the conductive tube controlled charging short delay circuits
- Conductive tube controlled charging delay circuit
- Lighting delay circuit using transistors Part 4
- Car headlight delay circuit
- Long delay circuit diagram 1
