Circuit diagram of an automatic water level controller
Source: InternetPublisher:清宁时光 Keywords: Automatic controller automatic water level control controller circuit diagram automation Updated: 2021/12/23
Water level controllers are widely used in industrial boilers, civil construction pools, water towers, water tanks, as well as open or closed storage tanks in petrochemical, papermaking, food, sewage treatment and other industries, and for liquid level measurement of various liquids in underground tanks. The detected media can be divided into various conductive and non-conductive liquids such as water, oil, acid, alkali, industrial sewage, etc. Together with the electric valve, it forms a set of advanced liquid level display and control equipment, which automatically opens and closes the electric valve.
The following is a circuit diagram of an automatic water level controller using the 555 circuit . The water level controller refers to the control of high and low water levels through mechanical or electronic methods. It can control solenoid valves, water pumps, etc., and become an automatic water level controller or water level alarm, thereby achieving semi- automation or full automation .
![Circuit diagram of an automatic water level controller](http://www.eeworld.com.cn/circuit/upload/d4296f5908de51254a5d02981c1d3057/f8189c9dae5dca460080c3319f3fb5c3.jpg)
- Fabrication of multi-cell lithium battery charging circuit
- Driving circuit of switching power supply field effect tube
- Op amp power supply decoupling bypass measures
- Simple and practical LED lamp driving circuit
- Low cost and high performance LED constant current power supply
- Electric bicycle battery charger circuit
- MIC4680 constant current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Adjustable voltage regulated power supply circuit
- Detailed explanation of mobile phone charger circuit diagram
- Power circuit of STR5412
- Power circuit b composed of intelligent thyristor modules
- Power circuit with smoothing filter capacitor
- Three-way DC-DC converter circuit
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- Multifunctional refrigerator DC voltage controller circuit diagram composed of 555
- Water level sensor and controller circuit diagram
- DC variable speed motor controller circuit diagram using optical fiber
- Water level automatic control circuit
