12kHz signal generator
Source: InternetPublisher:smallembedded Keywords: Signal Generator Updated: 2024/08/01
The 12kHz signal generator shown in the figure consists of a crystal oscillator and an alarm circuit. The oscillator output amplitude is stable, with a variation of <±0.26dB.
Component selection:
Transistor VTl, VT3: 9014, 65≤β≤115; VT2, VT4: 3DGl308, 60≤β≤85. Thermistor RT: RRWl-2. Quartz crystal SJT: BE42-12kHz. Transformer T uses ferrite MXD-2000, magnetic core is GV36X22, Ll-2Φ0.17mm high-strength enameled wire, wound 57 turns, L3-4Φ0.17mm high-strength enameled wire, wound 37 turns. The model of light-emitting diode VD3 is not limited. The nominal power of the resistor is 1/8W metal film resistor. The parameter values of other components are marked as shown in the figure, without special requirements.
- A crystal-controlled local oscillator circuit diagram
- 180~224kHz carrier frequency generator
- 70MHz crystal oscillator
- A/D converter with direct drive capacitive input composed of INA331/INA332
- Pulse wave generator with adjustable duty cycle
- A 1Hz clock generator circuit with COB
- 20~20000Hz low distortion audio oscillation circuit
- TTL level oscillator
- 2~20MHz variable frequency transistor oscillator
- Voltage controlled audio oscillator with 0.2% accuracy
- Various signal generator circuits
- Home appliance repair signal generator circuit
- Staircase wave signal generator circuit
- Voltage signal generator circuit with optical isolation
- Two examples of 60Hz time base signal generator circuit circuit-a
- Sub-audio tone signal generator
- simple tv signal generator
- Sequence signal generator circuit
- 450HZ signal generator
- Various analog sound signal generators
