Touch switch made of music doorbell chip KD-9300
Source: InternetPublisher:笑流年 Keywords: Switching Circuit Updated: 2024/09/29
The figure below is a touch switch made of the music doorbell chip KD-9300. The circuit is novel and interesting. It cleverly uses the function of the internal circuit of the doorbell chip to control the bistable trigger inside the chip with the help of the leakage current of the human body. We know that the music integrated circuit has a very high input impedance. When a person touches the "open" electrode M1, the leakage current of the human body is injected into the trigger terminal TRI of the music doorbell chip through R1, causing the bistable trigger inside the chip to flip, so that the entire doorbell chip presents a low resistance, the transistor VT1 is turned on, the relay K is energized, and the normally open contact can connect the controlled electrical appliance. When you need to turn off the electrical appliance, just touch the "off" electrode M2, and the leakage current of the human body is injected into the Vss terminal of the chip through R2, forcing the bistable trigger inside the integrated circuit to flip again, making the entire chip present a high resistance, VT1 enters the cut-off state, K loses power and releases, and the controlled electrical appliance is powered off.
To ensure safety, the resistance connecting the touch electrode sheet must not be lower than 4.7MΩ high-quality high-resistance metal film resistor.
- Peripheral circuit of automotive motor controller power supply chip
- Tutorial for building a remote-controlled Arduino Air-Boat
- A small improvement on the ordinary refrigerator motor starting circuit
- A small improvement to the temperature and water level indicator alarm
- Manual automatic air compressor control circuit
- Motor automatic cycle control circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- Hydraulic control circuit design and analysis
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Electric vehicle battery charging protection circuit
- Sound remote control switch circuit
- Touch switch power circuit
- Automatic periodic switching circuit 4
- Contactless proximity switch circuit 2
- Thyristor AC switch circuit one a
- One of the lighting sound and light control switch circuits
- Lighting sound-activated switch circuit using thyristors Part 2
- Touch lighting switch circuit four
- Ultrasonic remote control light switch circuit
- Sub-ultrasonic remote control light switch circuit (1)
