Internal structure of overvoltage converter
Source: InternetPublisher:ohahaha Keywords: converter arrester Updated: 2020/12/04
Electronic equipment and computer systems working at volt-level voltage levels are susceptible to damage by lightning strikes and overvoltage shocks caused inside and outside the equipment . For this reason, measures must be taken to prevent lightning strikes and overvoltage . In addition to installing lightning rods and lightning protection nets in buildings,
the following measures must also be taken.
Figure 20-31 shows the lightning protection wiring on the AC power line that introduces the uninterruptible power supply UPS. Install
ZGB 148A-20 , 220V at point B ; install ZGBls3A-60, 380V power supply arrester at point A ; install ZGB235J2-24 signal arrester at point C (computer and
electronic equipment input terminal); install the ZGB235J2-24 signal arrester at the antenna entering the communication machine Install
Z GB 003E-1 feederless arrester on the introduction line (not shown in the picture). The power surge arrester (protector) is composed of several protection function blocks
- Analysis of the working principle of switching regulator
- 220V Remote Load Monitor
- Basic circuit description of adjustable voltage regulator LM317
- Recommended circuits for different power on times of LM4911
- Simple and practical LED lamp driving circuit
- Boost drive circuit composed of RT8450
- A simple positive and negative power supply circuit
- UC3842 Electric Vehicle Charger
- Adjustable voltage regulated power supply circuit
- Practical constant current charger-----Constant current charger
- MC3406A inverting DC-DC integrated converter
- Three-way DC-DC converter circuit
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- Transistor stabilized current power supply circuit 2
- Combined circuit diagram with double integrating A, D converter
- Microprocessor power supply circuit diagram using flyback converter
- LTC1044 application example negative voltage converter
- LTC1044 application example voltage doubler converter
- Typical application circuit diagram of DC and DC converter composed of SI9114
