Homemade 40W electronic ballast
Source: InternetPublisher:笑流年 Keywords: Ballast Updated: 2024/09/25
The circuit is shown in the figure below. In the figure, the mains is connected from A1 and A2, D1-4 forms a full-bridge rectifier, C1 and C2 are connected in series to divide the voltage and filter. The two transistors and inductor L1-3 at the back form a half-bridge high-frequency oscillator. D5-6 protects the transistors from damage. Inductor L4 and C6 form a resonant circuit. After the lamp is ionized and turned on, L4 is used as a current blocker.
Component selection
The resistors, capacitors and transistors can be made as shown in the figure. Inductors L1-3 are wound with 3 single-core PVC wires on a toroidal core with an outer diameter of 10mm, an inner diameter of 6mm and a height of 5mm. L1-2 is wound with 2T, and L3 is wound with three turns. Pay attention to the connection method of the same-name terminals. L4 is made of EI-19 core. Since the author did not disassemble the component, the number of turns of the wire diameter is unknown. According to some information, it is about 200-300T.
- A simple magnetic switch circuit sharing
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- How to choose the right level of integration to meet motor design requirements?
- Model rocket launch controller circuit
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- A small improvement on the ordinary refrigerator motor starting circuit
- Do-it-yourself trial production of phase failure protection device
- Design and manufacture of three-phase motor protection circuit
- Infrared blocking alarm device
- Night dog barking anti-theft reminder circuit
- Multi-channel patrol detection control circuit a
- Simple timing control circuit
- fire smoke control circuit
- Photocell amplification control circuit
- Boiler control circuit
- PLC transmission line automatic reclosing control circuit
- Multi-pole leakage protector circuit b
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- Typical electronic volume control circuit
- Wide input range non-synchronous voltage mode control circuit
