Interface circuit for automatic counting using electronic counter b
Source: InternetPublisher:念慈菴 Keywords: Interface circuit electronic counter pulse signal photoelectric coupler Updated: 2021/10/25
The interface circuit for automatic counting using an electronic calculator is shown in the figure.
Figure (a) uses the travel switch so to be controlled by the photocoupler B;
Figure (b) uses the reed switch KR and pulse signal control;
Figure (c) uses the photocoupler B and pulse signal control, and the light-emitting diode VL is used to monitor the count Pulse operation;
Figure (d) is controlled by photoelectric tube LD and relay KA.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- Which one is better, NPN or PNP transistor?
- How to read resistor color codes? Resistor color codes illustrated
- How does sand become chips?
- DIY a decorative lamp
- Basic characteristics/working principles and application circuits of tunnel diodes
- How does RCCB work?
- Star finder battery indicator circuit
- LED Night Light
- An example of proportional integral circuit diagram
- Keyboard-display interface circuit
- Thyristor triggered interface circuit a
- LCD screen backlight boost circuit
- Optocoupler controlled oscillator
- MAX223-241 multi-channel data interface circuit (RS232)
- Interface circuit for automatic counting with electronic counter a
- Interface circuit between CMOS and PMOS d
- Interface circuit between CMOS and PMOS c
- Interface circuit between CMOS and NMOS b
- TTL and CMOS interface circuit a
