One of the operational amplifier stabilized power supply circuits
Source: InternetPublisher:太白金星 Keywords: Operational amplifier regulated power supply circuit BSP integrated operational amplifier Updated: 2021/01/16
Integrated operational amplifier , referred to as operational amplifier, is a DC amplifier with high amplification and deep negative feedback, which can be used
to combine and operate signals. Operational amplifiers are widely used in automatic control and other systems.
Since the operational amplifier makes numerous electronic components on an integrated circuit, the regulated power supply circuit composed
of the integrated operational amplifier has a simple structure. The operational amplifier itself
has the advantages of good component parameter symmetry and small temperature drift
, so its performance is very good.
The circuit is shown in the figure. When the input voltage of this power supply
is 10-20V, the output voltage is 9V, the current is 150mA, and
the internal resistance is 0. 003fl. Voltage stability <0. 002%, with overload
and short circuit protection functions.
It uses the field effect transistor VT as the adjustment tube, and
the reference voltage is formed by the resistor Ri and the voltage regulator tube vs.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How about the boost converter TPS61299?
- How to Make a Soft Latch Circuit
- Energy-saving motorcycle rectifier regulator
- Single-power supply circuit for ISO122P/ISO124
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Miniature polarity reversal power supply using MAX1721
- Power supply circuit that can reduce LM317 ripple
- LM317 regulated power supply
- Detailed explanation of mobile phone charger circuit diagram
- Motor forward and reverse control wiring diagram (2)
- Voice controlled flash LED light circuit diagram
- Electronic anti-asthma circuit
- Physiotherapy ventilator circuit
- Poultry warming temperature control circuit
- ring amplitude modulation circuit
- Parallel crystal oscillator
- Schiller oscillator circuit
- Three primary color display circuit
- Sawtooth wave generator circuit (1)
