PLC input interface light emitting diode display circuit a
Source: InternetPublisher:蓝猫淘气 Keywords: PLC light emitting diode interface display circuit Updated: 2020/01/08
For PLC circuits whose input power is DC, the input contact is the switching element S. In order to display the working status of the switch,
light-emitting diodes are often used as display elements. The light-emitting diode VL and the switching element s can be connected in parallel or in series.
Figure 13-55 (a) shows the parallel connection method, and Figure 13-55 (b) shows the series connection method. In the picture,,. is the equivalent resistance at the contact (approximately
lkfl); Ri is the input resistance of the PLC (approximately 3kfl); R is the resistance set to avoid malfunction of the PLC (approximately 1_5kfl).
- LED Flasher circuit using 2 transistors for LED switching
- Motor speed photoelectric control circuit
- Desk lamp dimming soft switch circuit
- Microwave Doppler warning circuit
- Three-way music lantern circuit
- Automotive LED driver circuit diagram using LT3486
- Frost alarm circuit
- Fluorescent dimming circuit (1)
- Photoelectric adjustment circuit
- Simple sensor alarm
- LED cycle lighting circuit controlled by 12C508A
- LED voltage measurement circuit diagram
- LED flash display circuit
- Fish tank flashing light circuit
- PLC external wiring diagram
- LED display drive circuit a
- Nickel cadmium battery charger circuit 2
- Connection between PLC and frequency converterb
- PLC input and output wiring a
- Fuse blown sound and light alarm circuit 3
