Logic level tester circuit 2
Source: InternetPublisher:fish001 Keywords: logic level tester light emitting diode Updated: 2021/10/20
It uses LM324 operational
amplifier A as the voltage comparator. When the input signal is high level
(compared with the threshold voltage set by potentiometer RP), the red light -emitting diode VLi in the three-color light-emitting diode VL
lights up, and VL2 does not light up; when the input signal is low level, the green light-emitting diode VLz lights up, VLi does not light up; when the input
terminal is a pulse signal, VLi and VLz flash alternately; when the frequency is higher, the luminous tube turns orange-red.
- Example of LED AC drive circuit
- Audio level LED and digital dual display circuit
- Fire safety evacuation emergency signs
- LED Flasher circuit using 2 transistors for LED switching
- Corridor automatic light-off device
- 4-digit incandescent lamp display circuit
- Colorimeter circuit
- One of the circuits that control one light in multiple placesb
- Microwave Doppler warning circuit
- Chandelier brightness controller circuit using thyristor
- LED voltage measurement circuit diagram
- Color display circuit
- Fuse blown sound and light alarm circuit 3
- Light emitting diode display circuit one a
- Multi-channel disconnection alarm circuit
- LED fuse blown indication circuit
- Nickel cadmium charger circuit diagram
- Integrated LED control board circuit 04
- Integrated LED control board circuit 01
- CMOS-Light Emitting Diode LED Interface
