Thermostatic control circuit using TL431 integrated circuit
Source: InternetPublisher:武林萌主 Keywords: Integrated circuit TL431 thermostatic control circuit thermistor Updated: 2020/01/09
It uses TL4 31 type or MA431 type three-terminal voltage stabilizing integrated circuit A as the temperature detection and
control circuit. Thermistor R. Use a thermistor with a negative temperature coefficient . Adjust the potentiometer RP to change the set temperature
value of the thermostat.
- A simple magnetic switch circuit sharing
- Servo motor pin diagram/working principle/application
- How to build a simple tachometer using an infrared reflectance sensor
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Design and principle analysis of practical electric curtain remote control device
- Design and analysis of wire control circuit
- Design and production of wireless multi-location control switch circuit
- Design and analysis of voice control circuit
- Infrared blocking alarm device
- Home wireless burglar alarm circuit
- Basic application circuit diagram of TL431
- Digital camera flash control circuit
- Thermostatic control circuit 2 using 555 time base integrated circuit
- One of the thermostatic control circuits using 555 time base integrated circuit
- TL431 AC voltage regulator circuit diagram
- Switching regulator composed of TL431
- Adjustable voltage stabilized power supply composed of MC7805 and TL431
- Electronic thermostatic control circuit
- TL431 programmable precision voltage reference circuit diagram
