Resistor spark suppression circuitb
Source: InternetPublisher:酷到被通缉 Keywords: BSP coil Updated: 2020/05/18
DC relays, contactors and electromagnets are inductive loads. When the coil
is powered off,
a high overvoltage will be generated at the contacts due to the existence of self-induced potential . It is added to the contact gap together with the power supply voltage to form spark discharge. This will not only accelerate contact
damage, but also generate a variable frequency signal that seriously interferes with radio communications. Therefore it must be eliminated.
It must be pointed out that using a spark suppression circuit will delay the operation of relays and other devices.
The circuit is shown in Figure 6-53. This circuit uses a resistor to provide a discharge circuit for the self-induced potential generated in the coil, so it is called
a resistor spark elimination circuit.
In the figure, L and R are the inductance and resistance of the coil ,,. is the spark suppression resistor , and S is the moving and closing contact.
For the circuit in Figure 6-53 (a), 2-3R can be selected; for the circuit in Figure 6-53 (b) , 3-5R can be selected.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- The meaning and importance of circuit protection, common types of circuit protection
- Design of an autonomous plant watering system using ATtiny85
- How can we make the robot move precisely on a predefined path?
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Methods for Eliminating Noise of Brushed DC Motors
- Add one more component to improve the phase failure protection function
- Design and analysis of voice control circuit
- Ultra-short wave item left behind reminder alarm
- Vibration anti-theft alarm circuit
