USB power socket using the car battery
Source: InternetPublisher:Lemontree Keywords: USB power socket Updated: 2024/08/15
Nowadays, many portable electrical appliances generally use USB ports as their power plugs. For example, portable reading lights use USB ports to charge their internal batteries. However, it is not appropriate for such small electrical appliances with large power consumption to use the USB port on a computer. In this regard, a USB power socket is provided here, which can use the 12V battery inside the car to power or charge portable devices that use a 5V USB port as a power source.
The attached figure shows a universal USB power socket circuit, which can safely convert the 12V battery voltage in the car into a stable 5V DC voltage. This circuit can power or charge any device powered by a USB power supply. The 12V power supply in the car is taken from the cigarette lighter socket on the dashboard.
The DC voltage from the cigarette lighter socket is connected to the three-terminal adjustable voltage regulator chip LM317L (IC1). C1 eliminates the noise in the input power supply. R1/R2 adjusts the output of the regulator to a stable 5V. This 5V is sent to the A-type USB female socket. The red LED indicates the output status. The voltage regulator diode ZD1 is used to protect the output from high voltage.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Driving circuit of switching power supply field effect tube
- Introduction and principle analysis of switching regulated power supply
- Visible laser digital control modulation driver
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Parallel DC regulated power supply circuit diagram
- Current/voltage conversion circuit using current converter
- USB power socket using the car battery
- Importance of Voltage Supervisors and Output Topology Selection
- 3v to 5v circuit diagram
- Voltage stabilization control circuit in power circuit
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- Recording level power supply circuit
- Common power circuits and applications 04
- Common power circuits and applications 03
- ±5V, ±12V power circuit A
- Small power UPS power circuit and production
- High quality power supply circuit schematic diagram
