Integrated regulated power supply with continuously adjustable output voltage
Source: InternetPublisher:方世玉223 Keywords: Regulated power supply LM317 Updated: 2024/08/15
This is an integrated voltage-stabilized power supply with continuously adjustable output voltage. The output voltage is continuously adjustable between 1.25 and 37V, and the maximum output current can reach 1.5A. The circuit is simple and very suitable for electronic enthusiasts to make by themselves. It can be used to power various small appliances. The
working principle
circuit diagram is shown in Figure 1. The output current of LM317 is 1.5A, and the output voltage can be continuously adjusted between 1.25 and 37V. Its output voltage is determined by two external resistors R1 and RP1. The voltage difference between the output end and the adjustment end is 1.25V. This voltage will generate a current of several milliamperes, which will pass through R1 and RP1 to the ground. The voltage divided on RP1 is added to the adjustment end. By changing RP1, the output voltage can be changed. Note that in order to obtain a stable output voltage, the current flowing through R1 is less than 3.5mA. The maximum power consumption of LM317 is 2W without a heat sink, and its maximum power consumption can reach 15W when a 200×200×4mm3 heat sink is added. VD1 is a protection diode to prevent the output of the regulator from being short-circuited and damaging the IC, and VD2 is used to prevent the input from being short-circuited and damaging the integrated circuit.
Component selection and production
The component list is shown in the table below.
serial number | name | model | quantity |
R1 | resistance | 100Ω | 1 |
RP1 | Adjustable resistor | 5.1K | 1 |
C1 | Electrolytic Capacitors | 2200u/50V | 1 |
C2 | Polyester capacitor | 0.33u | 1 |
C3 | Electrolytic Capacitors | 10u/50V | 1 |
C4 | Electrolytic Capacitors | 100u/50V | 1 |
VD1, VD2 | Rectifier diode | IN4002 | 2 |
U | Full bridge rectifier | 3A/50V | 1 |
IC | Adjustable three-terminal voltage regulator | LM317 | 1 |
T | Power Transformer | 28V | 1 |
After the welding is completed and checked, the machine can be used normally without debugging. However, when welding, please note that capacitor C2 should be close to the input end of the IC and C3 should be close to the output end of the IC, so as to better suppress the ripple.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- In-depth analysis of DC-AC converter inverter
- Practical and convenient fax machine power supply control circuit
- Driving circuit that controls LED brightness using PWM signal
- Simple and practical LED lamp driving circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- Power supply circuit that can reduce LM317 ripple
- CNC regulated power supply production
- Production of backup power supply for cordless phone
- MAX1811 Lithium Battery Charger Production
- Industrial product promotion and shopping guide DC power supply circuit
- Typical Reference Voltage and Power Supply Circuits
- Photoelectric control digital tube display circuit
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- Output 85 to 145V adjustable regulated power supply circuit
- Warm current power supply circuit b
- Timing switch AC power circuit
- Neon light high voltage power supply circuit
- Common power circuits and applications 08
