Simple medium wave radio circuit using varactor diode and TL081 linear op amp
Source: InternetPublisher:aerobotics Keywords: Radio circuit operational amplifier Updated: 2023/12/06
The figure shows the use of varactor diode VD2 as the tuning component to replace the variable capacitor. By changing the voltage applied to the varactor diode through the potentiometer RP1, its capacitance can be changed. Thus achieving the purpose of tuning. The tuning signal is detected by the diode VD1 and then applied to the operational amplifier A1 with a field effect transistor input terminal. After amplification, the output is connected to a 400-2000Ω load (headphones, small speakers or power amplifier input terminals, etc.). Adjust the potentiometer RP2 to change the amplification factor and thus the volume.
Some component specifications:
VD1: Germanium diode AA139 or similar device
RP1: 47kΩ wirewound potentiometer
VD2:Vianker diode BB312
RP2 1MΩ wirewound potentiometer
A1: Operational amplifier TL 081
- Why does CAN FD communication need to enable TDC for sending and receiving delay compensation? How to configure TDC and SSP in TCAN4550?
- FM transmitter in a matchbox
- Homemade FM wireless microphone for teaching
- Wireless doorbell production
- MICRFl04 ASK 470~300 MHz Transmitter
- RXM-921/916/903/868/433-ES Series Receiver Modules
- MAX2366/MAX2367/MAX2368 I/Q 2000-1700 MHz/1000-800 MHz dual-band
- RF2948B QPSK 2.4 GHz Spread Spectrum Transceiver
- RF2926 AM/FMASK/FSK/OOK 915/ 868/433 MHz Dual Conversion Transceiver
- TQ5638 KPCS CDMA/GPS 2090 ~ 1620 MHz Dual Mode Receiver
- Universal ultrasonic receiving circuit
- Pulse signal generating circuit b
- Practical amplifier circuit g composed of operational amplifier LM386
- Low output impedance operational amplifier circuit
- High input impedance buffer amplifier circuit
- Practical amplifier circuit f composed of operational amplifier LM386
- High Q Band Pass Filter Amplifier
- Humidity control circuit using D flip-flop and operational amplifier
- Butterfly 107-2 pocket radio circuit
- Clever use of LM386 as a multi-purpose radio circuit diagram
