Homemade active speaker for radio with noise reduction function
Source: InternetPublisher:走马观花 Keywords: Active speakers TDA2822 Updated: 2024/08/14
I have a Tecsun multi-band radio and often listen to shortwave radio to learn foreign languages.
But there are some drawbacks: first, the speaker inside the machine has a small diameter and large distortion; second, the noise is loud when listening to shortwave, which is especially obvious when playing with an external general active speaker. One day, I suddenly had an idea: why not make an active speaker with noise reduction function?
Considering that the radio has a mono output, only a mono speaker is needed. And because the broadcast is mainly voice, there is no need to pursue frequency response too much. I designed the circuit shown in the figure.
The left part of the figure is a noise reduction circuit with LMl894 as the core, which can effectively reduce noise by 10dB per channel. Among them, w1 is a 1kΩ adjustable resistor. The right half is the power amplifier part, W2 is the volume potentiometer, and the low-priced and easy-to-buy TDA2822 is selected here to form a BTL circuit. This IC has the advantages of simple circuit and high power.
When debugging, adjust the volume potentiometer to the appropriate position, input the radio signal and adjust W1 to make the noise reduction effect obvious and the distortion small. When using this speaker to play the radio, especially the shortwave, the annoying high-frequency noise is reduced a lot, the human voice is more prominent, and the effect is very satisfactory.
- Homemade high quality preamplifier tone circuit
- Using TDA2822 to do direct coupler output experiment
- Make a pocket amplifier with 8550 and 8050
- Toy electronic chicken
- Installation of electron tube differential amplifier circuit
- Typical application circuit of LM4903/4905 audio power amplifier
- LM4902 differential input audio amplifier circuit
- LM4903/4905 differential input audio amplifier circuit
- LMl876 is used to assist the audio power amplifier circuit
- Protection circuit and maintenance of household audio power amplifier
- TDA2822D power amplifier circuit diagram
- TDA2822 power amplifier circuit diagram
- Homemade multimedia active speaker 02
- A cost-effective active speaker 02
- A cost-effective active speaker 01
- Tube active speaker 02
- Tube active speaker 01
- Bookshelf active speakers 03
- Stereo mini power amplifier made with TDA2822
- TDA2822 wireless headset circuit diagram
