The fourth protection circuit to prevent short circuit when the motor is started in reverse
Source: InternetPublisher:containsmachine Keywords: Protection circuit motor short circuit BSP Updated: 2020/04/15
It uses voltage interlock relays KAi and KAz to ensure arc extinguishing during the forward and reverse switching process
In the picture. SA is the main command switch; KA3 is the undervoltage relay.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Servo motor pin diagram/working principle/application
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Design and production of wireless multi-location control switch circuit
- Design and analysis of voice control circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Magnetic door and window anti-theft alarm
- A novel and practical power line anti-theft and cutting alarm circuit
- Water supply reminder after water outage
- Bicycle anti-theft alarm
- Voice controlled flash LED light circuit diagram
- Pulse therapy circuit
- Frequency modulator composed of NE566
- ring amplitude modulation circuit
- Schiller oscillator circuit
- Broadband high frequency power amplifier circuit
- Voltage series negative feedback amplifier circuit
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Small current generator circuit
