Simple infrared detector
Source: InternetPublisher:笑流年 Keywords: Detection circuit infrared Updated: 2024/08/21
The simple infrared detector uses the photoelectric conversion characteristics of infrared diodes to detect infrared radiation within a range of 30cm to 50cm. It can be used to check whether your remote control functions normally, and can also be used as the front end in an infrared receiver circuit.
A gallium arsenide p-n junction diode (IR1) can generate about 100μA of current when exposed to visible or infrared light. The current generated is proportional to the intensity of the irradiated light. In this circuit, diode IR1 detects infrared radiation and generates a corresponding current, which is sent to the low-noise JFET op amp TL072 (IC1) for current/voltage conversion and amplification. The non-inverting input of IC1 is connected to the voltage divider formed by R1 and R2. The high-value resistor R1 and capacitor C1 can stabilize the non-inverting input. R3 is the negative feedback resistor of IC1.
When the power is turned on, LED1 lights up, indicating that the circuit is ready for detection. However, it will gradually go out because R3 draws current from the output terminal. At this time, the circuit enters the standby state, and IC1 outputs a low potential. LED1 does not light up.
Point the remote control at IR1 and press any button on the remote control. If the remote control is normal, an infrared beam will hit the detection diode IR1 and generate a corresponding current. LED1 will start flashing, indicating the presence of infrared light. To prevent IR1 from being disturbed by sunlight, a sunshade can be added around IR1.
- Simple and easy to make zero degree detector
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- Level measurement circuit composed of AD737
- NE555 makes a simple and practical acupoint detector
- Fire detector made with photodiode
- Four logic probe circuit diagrams
- 1.5V and 9V battery tester circuit diagram
- Fluorescent tube inverter circuit and emergency lighting circuit 02
- Light Detection 4 to 20mA Current Transmitter Circuit
- High current, high power amplifier circuit
- Valuables detection circuit design
- Induction cooker pot quality detection circuit
- Three-phase power supply phase sequence detection circuit
- α-ray application detection circuit
- Light detection circuit
- Long wave infrared detection circuit
- Differential light detection circuit
- Continuous flow pulse detection circuit
- Multi-light sensor Brinell hardness detection circuit
- Exhaust gas concentration detection circuit
