aytwartoofyoroo
L9942XP Microstepping Fully Integrated Motor Driver Evaluation Board
EVAL-L9942
The EVAL-L9942 is the Evaluation Board designed to provide the user a platform to evaluate the device L9942.
The L9942 is a motor driver for bipolar stepper motors with micro-stepping and programmable current profile look-up-table to allow a flexible adaptation of the motor characteristics and intended operating conditions.
Different current profiles can be chosen depending on target criteria: audible noise, vibrations, rotation speed or torque.
The decay mode used in PWM-current control circuit can be programmed to have slow, fast, mixed and auto-decay.
The programmable stall detection is useful to avoid running the motor too long time in stall position minimizing the noise.
The EVAL-L9942 board provides all the inputs and outputs capabilities necessary to drive correctly a bipolar stepper motor and also to monitoring diagnostic functionalities.
The board can be connected to the discovery boards developed for the SPC56 microcontroller.
Main features
  • Input signal connector compatible with the SPC56 Discovery boards. Possibility to connect the board to further microcontroller discovery or control boards by a simple adaptor.
  • Two output terminal blocks.
  • Wide supply voltage range (VBatt): 7 V ÷ 20 V.
  • 2 LEDs for monitoring V Batt and EN signal.
  • Device controlled and programmed via SPI.
  • L9942 diagnostic functions via SPI.
  • Test points to monitoring both input signals (SPI, PWM, EN, StepClock) and the four outputs (out power stage).
  • No heat-sink is required
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 06:05:03
