JFET
LET9060S based RF power amplifier for 2-way radios and general wireless services
STEVAL-TDR030V1
The STEVAL-TDR030V1 demonstration board is designed for 2-way radio BTS and general wireless services at 28 V to 32 V. It uses two LET9060S LDMOS transistors.
The demonstration board is a push-pull class AB power amplifier which uses a lumped L-C input/output network type on balanced microstrip lines.
A proper planar balun embedded on the PCB (patent pending) allows management of balanced versus unbalanced input/output signals.
For additional information regarding the LET9060S please refer to the device datasheet, available at www.st.com.
Main features
  • Excellent thermal stability
  • Frequency: 760-870 MHz
  • Supply voltage: 32 V
  • Output power: 100 W
  • Gain: 14 dB min
  • Efficiency: 45% min
  • Stability: load VSWR5:1 minimum
  • BeO free amplifier
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 14:10:19
  • I failed the CET-4
  • The function simulation is correct, but it is not correct after downloading. Why?
  • What are the advantages and disadvantages of double-layer PCB and multi-layer PCB?
  • ZTXZTX talks about lead-acid battery maintenance
  • 8086 address offset problem
  • True 100m dual-mode Bluetooth
