Lemontree
14 mm x 14 mm Dual Layer Antenna Reference Board for M24SR64 Dual Interface EEPROM
ANT7-T-M24SR64
The ANT7-T-M24SR64 antenna reference board is a ready-to-use PCB featuring an M24SR64-Y dual interface EEPROM connected to a 14 mm x 14 mm, 13.56 MHz etched RF double layer antenna on one side, and to an I2C bus on the other side.
The ANT7-T-M24SR64 demonstration board allows system designers to evaluate the M24SR64-Y performance and capabilities, and to get started with their design.
The ANT7-T-M24SR64 design and the Gerber files can be downloaded from www.st.com.
Main features
  • Ready to use printed circuit board including:
    • M24SR64-Y dual interface EEPROM
    • 14 mm x 14 mm, 13.56 MHz dual layer etched antenna
    • I2C test points
    • Open drain user configurable output to indicate an ongoing RF operation (GPO)
    • Digital RF disable input (DIS)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-02 17:30:32
  • Touch screen sampling problem (after each startup, the sampling value of the same point varies greatly)
  • Some things to know about PCB design
  • Can 430 be connected to 8255?
  • AVR timer compare mode problem
  • TF card receives design data
  • How does a mixed signal become a DC signal?
