sigma
Multi-channel LED driver with integrated boost controller for medium/large LCD panel backlight based on LED7708 and STM32F103C6T6 - daughter board
STEVAL-ILL035V2
The STEVAL-ILL035V2 product evaluation board is an extension (daughterboard) of the STEVAL-ILL035V1 (motherboard) based on the LED7708 LED driver. It allows implementation of a daisy-chained configuration for applications requiring more than 16 channels.
The LED7708 is configured as slave on the STEVAL-ILL035V2, and as master on the STEVAL-ILL035V1.
The boost controller section is not used and the supply voltage for the LED strings is derived from the motherboard (STEVAL-ILL035V1, master) by extending the output voltage optimization through dedicated hand-shake signals. Additional daughterboards can be connected to a single motherboard to increase the number of channels. The brightness control of the LED strings and the fault management options are identical to the ones available for the STEVAL-ILL035V1 evaluation board. The evaluation board is intended as a solution for medium/large LCD panel backlight drivers, but is suitable for any application involving several LEDs arranged is strings (e.g. advertisement panels, signs, gaming, etc.).
Main features
  • Wide DC input voltage: 10 V - 28 V
  • 16-channels with up to 85 mA/channel current capability and independent PWM brightness control
  • Up to 15 white LEDs per channel
  • Embedded open-channel and LED short-circuit faults management
  • Expansion connector to cascade other STEVAL-ILL035V2 evaluation boards
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 01:40:42
