ghaytweyhtoo
3.2 W LED power supply based on HVLED805
STEVAL-ILL037V1
The STEVAL-ILL037V1 demonstration board implements a 3.2 W (16 V / 0.2 A) wide range LED driver to support from 3 to 5 LEDs for LED lamps (e.g. E27 and GU10).
The HVLED805 is an offline all-primary sensing switching regulator, specific to offline LED drivers, based on quasi-resonant ZVS (zero voltage switching at switch turn-on) flyback topology, due to its simplicity and low cost.
Main features
  • Input voltage: 90 Vac - 265 Vac
  • Input frequency: 50 Hz - 60 Hz
  • Output power: 3.2 W
  • Expected efficiency: 85%
  • Output voltage: ~16 Vdc (from 3 to 5 LEDs)
  • Output current: 200 mA
  • For E26/E27/GU10 LED lamps
  • RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-17 22:03:51
