newlandmark
L5964-based digitally controlled DC-DC converter up to 5A designed for automotive and transportation applications
AEK-POW-100W4V1
The AEK-POW-100W4V1 is a very compact DC-DC converter for automotive and transportation applications which allows regulating the output voltage in two different modes: fixed outputs and PPS (Programmable Power Supply) with 20 mV steps.
[AEK-POW-100W4V1 IMAGE]
The AEK-POW-100W4V1 allows to set the output current from a min. of 0.05 A to a max. of 5 A for the entire output voltage range with 50 mA steps.
The AEK-POW-100W4V1 includes several protection systems: short-circuit, overcurrent and thermal protection.
The AutoDevKit software library includes dedicated components able to configure and drive the board from ST microcontrollers.
主要特性
Up to 100 W power on a single DC-DC channel
Input voltage range: 6 V to 26 V
MCU selectable fixed outputs: 3.3 V, 5 V, 9 V, 15 V, 20 V
Programmable max output current up to 5 A with steps of 50 mA
Programmable output voltages: 20 mV steps from 3.3 to 11 V
Short circuit, over-current, thermal protections
Size 84.7 mm x 81.3 mm
Included in AutoDevKit initiative
RoHS compliant
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 06:37:23
  • [Ask TI] LM3S811 PWM output problem
  • Two key points of capacitor filtering!
  • Schematic diagram of the life sign detection watch
  • 51 MCU controls RTL019AS
  • Earn points~~~
  • dsp(tms320VC5502)+isp1581 usb2.0 high speed data acquisition solution
