qoistoochee128
Single mos four-way control motherboard
Go directly to the code and test it. There is no explosion or fire. Note that this is the video received from the receiver. The first speed is about 1/4 of the full speed. Later, a better control motherboard will be released.  IMG_20200917_214010.jpgIf you don’t have Arduino basics, don’t do it. IMG_20200917_090735.jpg
#define PINX 11
#define PINY 2
#define PINKG 7
#define LEDA 12
#define LEDB 13
#define PINLU 5
#define PINLD 6
#define PINRU 10
#define PINRD 9
int TZ=40;//速度调整
int speedcal=0;
int Direction;//方向原始数据
int correctionXR;//x修正后的X
int correctionXL;//x修正后的X
int spd=255;
unsigned long Speed;
unsigned long KGSG;
void motorprint();
void motorcontrol();
void dealX();//X方向调整
void motorprint()
  pinMode(PINX, INPUT); //设置引脚为输入模式
  pinMode(PINY, INPUT); //设置引脚为输入模式
  pinMode(PINKG, INPUT); //设置引脚为输入模式
  pinMode(8, INPUT); //设置引脚为输入模式
//    pinMode(PINLU, OUTPUT); //设置引脚为输出模式
    pinMode(PINLD, OUTPUT); //设置引脚为输出模式
    pinMode(PINRU, OUTPUT); //设置引脚为输出模式
//    pinMode(PINRD, OUTPUT); //设置引脚为输出模式
//    digitalWrite(PINLU,LOW);
    digitalWrite(PINLD,LOW);
    digitalWrite(PINRU,LOW);
//    digitalWrite(PINRD,LOW);
    pinMode(LEDA, OUTPUT); //设置引脚为输出模式
void motorcontrol()
  if (Direction>TZ/2+3)
       speedcal=constrain(map((Speed+Direction),Speed,310,Speed,250),Speed,250);
//     analogWrite(PINLU,speedcal);
       analogWrite(PINLD,speedcal);
       analogWrite(PINRU,Speed);
//     analogWrite(PINRD,Speed);
  else if (Direction<TZ/2-3)
//    analogWrite(PINLU,Speed);
      analogWrite(PINLD,Speed);
      analogWrite(PINRU,speedcal);
//    analogWrite(PINRD,speedcal);
  else
void setup()
  Serial.begin(19200);
  motorprint();
void loop()
  /*Speed =pulseIn(Y, HIGH,80000);
Direction =pulseIn(X, HIGH,80000);
 KGSG = pulseIn(KG, HIGH,80000);*/
  KGSG = pulseIn(PINKG, HIGH,80000);
  if(KGSG<1100)
  spd=3;
  else if(KGSG<1700)
  spd=2;
  else if(KGSG<2000)
  spd=1;
  else
  spd=255;
  Speed=(constrain(map(pulseIn(PINY, HIGH,80000),989,1968,0,240), 0, 240)/spd);
  Direction =constrain(map(pulseIn(PINX, HIGH,80000),998,1982,0,TZ),0,TZ);
  if (pulseIn(8, HIGH,80000)<1500)
  digitalWrite(LEDA,HIGH);
  TZ=70;}
  else{
  digitalWrite(LEDA,LOW);
  TZ=50;}
/*  Serial.print("速度:");
  Serial.print(Speed);
  Serial.print(" 方向:");
  Serial.print(Direction);
  Serial.print(" 控制:");
  Serial.println(KGSG);*/
  if (Speed<10)
    Speed=0;
    motorcontrol();
  else
   motorcontrol();
Search Datasheet?
Forum More
Update:2025-07-13 08:00:00
  • Three-phase PFC, current loop does not converge using VIENNA topology
  • Can the administrator hold an activity to learn about AVR?
  • st F7 + Elderly emergency call + Try Super Mario
  • Division and shifting in embedded C language
  • [LPC54102] + General hardware setup
  • SensorTile boot process
