通通
#The Fifth Lichuang Electronic Design Competition#Smart hearing aid/USB sound card
Note: * is required.
[Please fill in during the registration stage↓]   1. Self/team introduction Two electronic enthusiasts   2. Brief introduction to the project This project designs a portable smart hearing aid/USB sound card with a volume of 60x90x10mm. It is similar in size to an old-fashioned clamshell machine and is easy to carry. Built-in charging management circuit can achieve long battery life. In terms of performance, ADC 128x sampling rate, the current audio SAI interface is 44.1Khz sampling rate.
[Please fill in during the competition stage↓]   1. Describe the project details. This design uses the architecture of MCU + audio processing chip + SDRAM to achieve high-speed audio processing. The MCU is used to initialize and configure the audio chip, and the read audio is processed through the algorithm. Perform fast calculations and output with the built-in FPU (SDRAM is currently not used and is reserved). In terms of battery life, Yutai's power management chip is used for charge and discharge management. In terms of interaction, it is equipped with a resistive touch screen to achieve touch interaction.   2. Describe the challenges faced by the project and the problem software it solves: Audio algorithm: The current audio processing mainly uses the EQ processing that comes with the audio chip. Currently, the 32 internally only reads the audio data processed by the audio chip through the SAI interface. Forwarded directly through DMA. Intelligent adjustment algorithm (hearing aid): Through touch screen interaction and a series of self-adjustment guidance, users can adjust the hearing aid to the most appropriate parameters. Hardware: Cost issue: Currently, the STM32H7 series of chips is used, which is expensive (it is currently in the testing phase. In order to avoid insufficient performance that delays the project progress, high-performance chips are directly used. The chips will be reduced based on the test results in the future. Specification).
  3. Describe the key points involved in the hardware and software parts of the project. The hardware is divided into four parts: ①Audio processing part (MIC input filtering, layout and routing) image.png         ②Human-computer interaction part (using a resistive screen touch solution) image.pngimage.png     ③Power management part, The solution of Yutai is used (which can realize fast charging). The power is collected in the upper left corner of the picture above, and an op amp is used to follow the reading voltage. image.png     ④Storage part (SDRAM+FLASH) image.pngimage.png   4. Project material list display~~~~
total amount bit number Attributes encapsulation
43 C1,C3,C8,C11,C18,C26,C29,C30,C31,C33,C36,C42,C43,C45,C46,C47,C48,C49,C50,C51,C52,C53,C54,C55,C56, C57,C58,C59,C63,C64,C65,C69,C70,C72,C73,C74,C75,C76,C77,C78,C79,C80,C81 100nF_50V_10% C0603
9 C7,C10,C17,C21,C22,C24,C27,C28,C37 10uF_25V_20% C0805
2 C9,C12 220uF_10V_20% CAPAE530X530N
9 C13,C14,C15,C16,C19,C20,C61,C68,C71 1uF_16V_20% C0603
2 C23,C25 220pF_50V_10% C0603
3 C32,C34,C35 2.2uF_16V_10% C0603
2 C38,C39 6pF_50V_0.25pF C0603
2 C40,C41 22pF_50V_5% C0603
1 C44 10nF_1KV_10% C1206
1 C60 3.3nF_50V_10% C0603
5 C62,C66,C67,C82,C83 22uF_25V_20% C0805
5 D1,D2,D3,D4,D5 led LED0603
2 FB1,FB2 220R_100MHz_25% R0805
7 FB3,FB5,FB6,FB7,FB8,FB9,FB10 10R_100MHz_25% R0805
3 FB4,FB11,FB12 0R_100MHz_25% R0805
2 J1,J2 PHONOJACK
PJ-342 PJ-342
1 J3 CON5 SHDR0S254P5X1_1300X250X500
1 J4 CONN
PWR 2-R SMD_XH2D54_2P
1 LCD1 TFTLCD_2.8 tftlcd_2d8
1 L1 1uH/7A jshc0515
2 MIC1,MIC2 MIC MIC_6MM
1 Q1 SS8050 SOT95P237X112-3N
1 rsn1 1R_5% R0603
13 R1,R2,R3,R4,R5,R7,R12,R13,R14,R15,R23,R51,R55 0R_5% R0603
13 R6,R18,R19,R20,R24,R25,R29,R30,R32,R43,R52,R56,R58 10K_5% R0603
2 R8,R10 680_5% R0603
2 R9,R11 47K_5% R0603
3 R16,R39,R41 1K_5% R0603
3 R17,R50,R54 100K_5% R0603
3 R21,R26,R31 4.7K_5% R0603
1 R22 NC_0R_5% R0603
2 R27,R28 22R_5% R0603
2 R33,R40 1M_5% R0603
1 R34 510K_5% R0603
1 R35 72K_5% R0603
4 R36,R38,R42,R44 500R_5% R0603
1 R37 51K_5% R0603
1 R45 270K_5% R0603
4 R46,R47,R48,R49 NS R0603
2 R53,R57 22K_5% R0603
1 SW1 WKUP SMT_3X6_SERIES_TACT_SWITCH
1 SW2 UP SMT_3X6_SERIES_TACT_SWITCH
1 SW3 DOWN SMT_3X6_SERIES_TACT_SWITCH
1 SW4 BUTTON SMT_3X6_SERIES_TACT_SWITCH
1 SW5 BUTT SMT_3X6_SERIES_TACT_SWITCH
2 TP5,TP7 T
POINTS TEST_3D_R
2 TP6,TP8 T
POINT R TEST_3D_C
1 USB1 TYPE_C_31_M_12 TYPE_C_31_M_16
1 U1 AMS1117_3.3V SOT230P700X180-4N
1 U3 WM8978 QFN50P500X500X80-33N
1 U4 XPT2046 TSSOP65P640X110-16N
1 U5 RS6331 SOT23-5-95P280X112-5N
1 U6 STM32F429IGT6_LQFP176 LQFP50P2600X2600X160-176N
1 U7 ETA6980 QFN45P400X400X80-29N
2 U8,U9 HXJ8002 TSOP127P600X140-8N
1 U10 W9825G6KH-6 TSOP80P1176X120-54N
1 U11 GD25Q32CSIG SOP127P790X140-8N
1 Y1 25MHz SMD-3225-4P
1 Y2 32.768KHz SMD-3215-2P
* 5. Upload project pictures 5.1. Print the competition logo picture on the PCB. Failure to do so will be deemed as giving up the competition.
3D rendering effect picture: image.pngimage.png     Actual picture: (The interface is planned to be developed using LVGL, and currently only process testing has been run) image.png
image.png           5.2. Other pictures of the project image.pngimage.pngimage.png * 6. Demonstrate your project and record it as a video for upload 6.1. Official website of the video upload competition 6.2. Video title and link at Station B
Notes: ①: Video requirements: Please shoot horizontally, the resolution is no less than 1280×720, the format is Mp4/Mov, the size of a single video is limited to 100M; ②: Video upload: please upload to the official website of the competition and Station B simultaneously ( www .bilibili.com ), the top 10 most popular projects at Station B will receive a cash reward of 1,000-5,000 yuan, and other uploaded projects will receive a 100-yuan Lichuang Mall no-threshold coupon; ③: Video title: The 5th Lichuang Electronic Design Competition: {Project Name }-{Video module name}; such as the 5th Lichuang Electronic Design Competition: "Autonomous Driving" project - team introduction.
  7. Whether it is released to the public for the first time. 7.1. Whether the project has been published or won an award before, please explain. None. 7.2. If the project is optimized on the original basis, please explain the optimization part. None   . 8. Open source documents. None* 9. References. Punctual Atomic H7 Development Board ~~~~
Click the link for more details: https://www.szlcsc.com/go/dsxq
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-07 03:01:58
