aerobotics
USB type-C to A bidirectional converter
USB type-C to type-A bidirectional converter.
You can convert between type-c, type-A male, and type-A female interfaces, and use the type-C data cable as a type-A extension cable or OTG cable.
If using c-to-c cable:
1) Turning the switch to the direction of the typeA female port will trigger the power supply + host mode of the typec device, which can be used as an otg line and powered by the C port device.
2) Turn the switch to the male direction and it can be used as an ordinary a-to-c data cable.
In 2 state, the QC fast charging of some type-c devices cannot be used directly, but it can be used again by using another adapter to transfer it back to the A port and then connecting the normal A-to-C cable. If you know the reason, you can point it out in the comment area.
The three interface pins are straight through. When using data transmission/fast charging, please do not connect 3 interfaces at the same time to avoid errors or burning the device!
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 02:54:53
