containsmachine
ESP8266 split flat heating table HeatPlatform_SMT
Project origin
The flat heating table can facilitate manual patch welding of PCBs. I am a Beidiao software engineer and an electronics enthusiast. For the convenience of moving, the choice of tools always favors convenience. The finished flat-panel heating tables on the Internet are often relatively heavy, so I decided to build one myself.
Communication group
Add this QQ group 148563337. If you need more friends, you can consider doing it together.
  1. Using PID control algorithm, the temperature control range of the controller is room temperature ~1000 degrees Celsius. (The actual upper temperature limit needs to consider the heating table material)
  2. Currently, it stably supports heating plates with a power of 2000W. (Can be modified to support greater power)
  3. The screen uses a 0.96-inch OLED (SSD1306) LCD display.
  4. Use a rotary encoder instead of button operation to improve user experience.
  5. Supports temperature curve control. (Support coming soon)
  6. Supports firmware upgrade via wifi (updated later). Link ws://192.168.4.1:8266/
Project contains
  1. A complete set of self-made tutorials for Bilibili (waiting for update). Bilibli video link https://www.bilibili.com/video/BV1ky4y1m7ZF
  2. Temperature control system based on ESP8266.
  3. The hardware control circuit of the temperature control system.
  4. 3D structure diagram of the controller's housing.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 04:52:26
