containsmachine
[Training Camp] High-power modular RGB driver board +488694A
This module does not have a built-in light and requires an external 5050RGBW light strip. You can also connect an external white lighting strip and an RGB color strip to a driver board at the same time to achieve the RGBW effect.
The main control board is powered by ATX2.31 standard desktop power supply, and the power supply directly provides 3.3v power supply. The switch button directly controls the on/off of the ATX power supply. A single switch can control the power supply of all drive modules, and the switch does not pass high current, making it more durable.
The main control board can connect 12 drive modules through cables to achieve a terrifying total output power.
The driver board uses four 40V202A MOS tubes. There is a voltage difference between the MOS tube heat sinks, and they must be insulated when installing the heat sink. The driver board uses the ATX power supply graphics card 6pin to provide 12v power supply, making full use of the second-hand mining machine power supply.
When the temperature of the 5-meter high-bright warm white light strip is about to exceed 100, the corresponding mos tube is less than 40 degrees without a heat sink.
Please use a safe and qualified ATX power supply for power supply. The drive signal relies on the power supply line to achieve a common ground. Please try to use a single, original ATX power supply. When using multiple power supplies, connect the negative terminals of the low-voltage electrical output sections of all power supplies.
On the reverse side, a half-sugar picture is specially added for metaphysical blessing.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 20:36:03
