JFET
Bluetooth QCC3008 board
Bluetooth 5.0 audio decoder board
A new generation of Bluetooth decoder board will be released soon. It still uses the QCC3008 Bluetooth module. I would like to support it! For this generation upgrade, I used dual TPA6132A2 chips. One chip does the front differential conversion, and the other does the front differential conversion and ES9023 decoding. The two chips output the mixed audio signal. In this way, you can easily drive the headphones. In addition, the audio from the i2s signal decoding part is also introduced. If you don’t want to listen to the mixed audio, you can directly connect to the i2s decoding part to listen to music! The mixed audio part can be used to make calls directly through the microphone of the headset!
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-06 02:38:13
