newrudeman
poker mechanical keyboard gh60 standard poker configuration
WeChat picture_20210304165932.jpgWeChat picture_20210304165922.jpg 2021-03-02 I updated the schematic diagram and PCB (mypoer_final). I have been using the keyboard myself. Basically, there are no major problems and it can meet my own needs. However, there is still room for optimization (after all, I am an amateur). Rookie), I’m busy with work and don’t have time to mess around.
2020-8-18 Updated version of geber file and BOM table. It has been used for more than a month. It is quite stable. The PCB satellite axis hole position has been added to optimize the positioning hole position. The RGB lines are divergent, different from the serpentine wiring. , you can use it directly to make boards (complaining, I feel that EDA is not easy to use after the update, and the top menu is not as intuitive as the old version)
image.png 32u4 main control, added Kaihua axis seat for easy axis change, 3528rgb reverse-mounted lamp, I think the monochrome lamp is too monotonous, I can simply switch colors, but the rgb gradient does not seem to work well, the rgb is used as a light strip in the qmk firmware, I It is purely a personal hobby to use it as a backlight. The CAPSLOCK lamp uses a straight-in LED lamp bead. A hole is opened on the positioning plate to stick out. The indicator light is more obvious. The PCB satellite axis is not added if there is no need. It has a type c interface. The one chosen is easier to weld. Having said all this, I haven’t actually used it yet. I’m going to make a board and solder it myself. I’ll update it when I’m done.
If there is anything wrong, please correct me.
2020-6-3 Update The board does not recognize the USB device after it is soldered. There is no short circuit or the like in the test. It may be a problem with the Pcb wiring. I don’t understand many things when I draw it for the first time. There is no differential wiring for the signal lines. I don’t know. That's not the reason. I made a small board and tested it. If it's ok, I'll draw another one.
Updated on June 8, 2020. I made a small board and tried it. There was no problem. The previous one was probably a wiring problem. I drew a new one and will try again after it is shipped. TIM picture 20200608091332.jpg
2020-6-13 The second updated board has arrived. It is no problem to solder and flash the firmware. The PCB file has been updated~~~~. However, there is a problem with the positioning and slotting of the screws on this board. I made a mistake in the size and cannot fix the bottom case. I am going to draw another version. This board can be used. If you have the conditions to make the case yourself, you can try it. TIM picture 20200613103949.jpg
Updated on 2020-6-20
keyboardlayout.jpg Default layer and Fn layer functions
PN layer function.jpg The PN layer function is mainly the adjustment of RGB lights plus a RESET
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 14:39:57
