兰博
TypeC power pickup card
5V and 3.3V power supplies are often used in experiments, but only 5V can be output through the USB cable in hand, so I drew a TypeC power supply card, and the 5V and 3.3V voltages can be connected through the USBTypeC cable. In addition, the CC pin of the USB TypeC interface is also considered, and a 5.1K resistor is pulled down to adapt to most TypeC power ports.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 22:51:12
  • The difference between electronic ABS and mechanical ABS
  • MO5R 5VLC 1N96F CTUBRV
  • See how much it’s worth!
  • How to use ordinary probes to perform differential measurements?
  • ADI dual-channel 16-bit DAC achieves the industry's highest signal bandwidth
  • Questions about zigbee protocol stack infrared
