兰博
[Training Camp] Smart night light 658550A based on Tuya networking module
1: Project Introduction
The smart night light remotely controls a 2-way night light circuit through the WIFI & Bluetooth communication module provided by Tuya. The project is a 0-code development based on the Tuya module, which is friendly to beginners. By controlling the night light through Tuya's mobile APP via WIFI or Bluetooth, you can manually adjust brightness, switch between warm light and white light, set delay and timing, set sensor mode, set intelligent linkage, and view sensor records; it is inconvenient to use. When using a mobile phone, it can also be used as a desk lamp to achieve physical key switches and dimming. The Tuya module provides two connection methods, WIFI and Bluetooth. WIFI is used for remote control and Bluetooth is used for close range control, which can meet the needs of most users. During the soldering circuit and circuit inspection, some deficiencies were discovered, and then the circuit and engineering were improved.
[Link to Tuya IoT development platform] https://auth.tuya.com/from=https://www.tuya.com/cn/&_source=cbc30f99f7a6c4aebca6755c2fab437f (contains detailed development documents)
2: Functions implemented by the project
1. WIFI and Bluetooth control night light switches, etc.
2. Use the Tuya Smart APP on your mobile phone to switch between warm light and white light and adjust the brightness of the light.
3. Functions such as delay and timer switching can be set on the Tuya Smart APP on the mobile phone.
4. You can set the sensing mode on the Tuya Smart APP on your mobile phone, add functions such as intelligent linkage and view sensing records.
5. Physical key switch, warm light and white light switching, and brightness adjustment can be realized on the night light.
6. It can realize the charging and discharging function of 3.7-volt lithium battery, with battery discharge protection.
7. It can detect the human body and turn on the light for a period of time.
Three: Actual picture of night light
4. Warm white light switching diagram
White light lighting diagram
Warm light lighting diagram
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 14:39:45
