MartinFowler
H-bridge driver module
H-bridge drive circuit designed based on IR2104 half-bridge drive circuit and IR7843 160A 30V ultra-low internal resistance NMOS tube, with forward and reverse indication, with enable pin IR2104 can be powered independently
It can increase the driving voltage of MOS and reduce the internal resistance. It can still work normally at 600KHz. IR2104 can be replaced with EG2104. It can achieve pin-to-pin compatibility and stronger driving capability. v1.1 has modified a few errors on the original basis and made fine adjustments. silk screen layout IMG_20200312_120641.jpgIMG_20200312_120609.jpg
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 15:03:26
  • Please help me find what is wrong
  • Dear Bms forum experts, I would like to ask if you use the battery simulation system when testing Bms?
  • Who can draw 3D models?
  • LPC1768 timer timing accuracy
  • 【Low Power】Second Generation Serial RapidIO and Low-Cost, Low-Power FPGAs
  • Frequency meter top circuit design
