super_star
WS2812/SK6812 light board based on ESP8266
In terms of hardware, the microcontroller uses ESP8266 microcontroller and STC microcontroller (HI3861 can be added), which can be customized through MiSiQi and HaoHaoTaichan. The lamp beads are made of ws2812 and sk6812 colored lamp beads, and every 23 lamp beads are in a group, a total of 1 group. Reserved pin header, you can download the program through the serial port or communicate with the main control MCU of the light board through the serial port. It can be connected to the STC main control light board. It has a display interface and can be equipped with a display screen to check the status. It has an AIC1084 high-power power chip and can be used as a The power output is equipped with a buzzer. The sound can be emitted through the push-pull mode of the microcontroller. The volume is adjusted through the duty cycle. The software part adopts Misiqi and Haohaochai graphical programming, which is easy to understand and easy to operate.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 06:21:59
