ghaytweyhtoo
FPV rack-1.6 inch-Baby Nazgul magic modification
Baby Nazgul rack revision
Design Principles:
  1. There must be a light and BB ring circuit (the light is 0605LED self-flash, WS2812 has two specifications, 1206 and 5050; it can be customized as needed)
  2. The overall weight does not exceed 20g
  3. In principle, only flight control hole positions supporting 16 and 25.5Aio are supported.
  4. In principle, the V1 version only supports 14MM image transmission bits. The base plate is mainly adjusted.
  5. The upper and lower covers of the large version are universal, and the integrated design supports camera covers and antenna ports.
Blade size reference
Blade model 4 weights Center thickness mm Center hole a fixed way Diameter/radius mm
GEMFAN 35mm-3 1.4 inch  Taobao link 1.28g 4.5mm 1mm   fasten 17.5/35
GEMFAN 40mm-1.0MM 2 leaves, 3 leaves, 4 leaves 1.6 inches  Taobao link 2g 5.2mm 1.5mm screw 20/40 ❤️
EMAX AVAN Blur 2-inch 3-leaf  Taobao link 4.4g       48.26 / 24.13 (1.9 inches) ✅ v2.x
2020 4leaf Taobao link 3.64g  4.5 1.5 screw 50.3/25.15 ✅ v2.x
2345 Taobao link 7.2g       58/29 ❌
LED resistance calculation
The R1 bit is a resistor, connected to the LED lights on both sides. You can use 0603 or 0805 for the light. It is recommended to use self-flash. Taobao link
It doesn’t matter if there are more or less resistors. You don’t need to be very precise. Some common resistor notes:
1. 20 LEDs: 8.2
2. 16 LEDs: 10 ohms
http://www.chinaaet.com/tools/led_current_limiting_resistance.html
Rack version
v1.2
  1. There are lights and BB sound circuits
  2. The base plate, upper plate and camera bracket (14MM high) are integrated into one
  3. It can be printed directly, the overall size is 9.51cm, 9.69cm
  4. The reinforcing ribs were adjusted to the appropriate width. In order to add lights, two of the three holes were changed.
  5. There is an m2 14mm camera position at the tail, which can be fixed at the bottom or used to tie the ELRS antenna
white effect red effect total measurement
v1.3
  1. The upper cover supports direct plug-in of 18650 batteries✅
  2. Corrected the height of the camera bracket integrated in the bottom plate to the commonly used 20mm 15mm height✅
  3. Adjust the circuit spacing, correct the 3 screw holes of the motor -> 4 screw holes, and adjust the areas that are too thin, such as the edge of the 14mm through hole at the tail✅
  4. A G-shaped motor cable bracket is added at the rear , which is suitable for holding the XT30 18awg cable.
  5. Camera card link removed to protect fragile circuitry
v2.1 (1.9-inch paddle version)
  1. Supports larger paddles, up to 54mm, can support 1.9-inch and 2-inch (2020) paddles✅
  2. Reduce the number of lights to 4 (*2) on one side, and the whole machine can have up to 16 lights, with double-layer wiring.
  3. The camera bracket supports ELRS T-type antenna front
  4. The motor base holes are all metalized, making them more durable and dissipating heat faster.
  5. 1.4mm screw holes are added to the four corners of the machine arm to fix the bracket.
v3 (1.6-inch paddle PUDY-Little Fatty)
  1. Reduced size to reduce wasted space (wheelbase 78, overall within 75x73), suitable for 1.6-inch propellers (40mm)
  2. Remove stiffeners to reduce wind resistance
  3. Optimized the solder joints of LED lights, making them more beautiful
Other photos
Comparison between 1.9 inches and 1.6 inches Comparison between 1.9 inches and 1.6 inches 1.9 inch upper 2020 paddle
hx115 in the cosmetic box 1.9 inches in the cosmetic box 1.6 inches put in the box
1.6 inch lower paddle Add wheels 3 blade propeller
bottom light Bottom light 2 Camera stand to watch "Peppa Pig"
Pudgy bottom light up baby19 has lights up and down view from below
How to create boards for free on Lichuang
The second step is to place an order with one click. There are some parameters you should pay attention to.
The third step is to configure. Basically, just stick to the default. Just set the [Color]. The subsequent pictures will not appear. .
Special thanks list:
Pest control FPV
参考设计图片
Design Files
Search Datasheet?
Forum More
Update:2025-08-04 06:02:48
