念慈菴
PythonIot-Grove-UNO
For teaching, the goals of the IOT project framework based on Armbian and Python languages
1. Log in to the Jupyter service in one step (based on RNDIS driver-free);
2. Learn Python programming and quickly develop Python-based IOT Internet of Things projects;
3. Learn standard Linux operations System;
4. Use Python to call GPIO/Sensor hardware;
5. Built-in Siot LAN MTQQ protocol;
6. Built-in OpecnCV;
Note: OrangePi Zero/NanoPi Neo (based on Allwinner H2+/H3 core) has been verified so far
Get started quickly with PythonIOT
Teaching goals: experience the Linux operating system (terminal command line), learn Python programming (based on Jupyter ), Internet of Things hardware programming ( Siot/MQTT ), network communication principle experiments, OpenCV face recognition, etc.
1. 45- minute quick introduction
Run the first command line command, run the first Python code, run the first hardware project ( one light, one button , OLED display). The entire training is controlled within 30 minutes, leaving 15 minutes for practical operation, exploration and communication. .
1.1 Connect to PC via USB cable and wait for the driver to be automatically installed;
1. Win system usually does not require driver. In some cases, it will be recognized as a COM port, and the driver needs to be updated manually. First download the driver, run the fifth CMD file ( http://www.qudong51.net/qudong/540.html ) as an administrator , and then install the driver on the device. Double-click the COM port recognized by the USB serial port in the manager and select Computer to find and update the driver. (see appendix)
2. For Linux -compatible systems such as Ubuntu , X86 is automatically installed and verified.
3. Install HoRNDIS-9.2.pkg on Mac system , download address https://joshuawise.com/horndis , and pass the test.
1.2 Enter http://pythoniot.local in the browser to enter the jupyter interface, password: 1950
Note : The startup is slow for the first time. Just press RESET to restart the system. There is no need to repeat the above process for future uses.
1.3 01_Helloworld.ipynb asks where the world is
1.4 02_helloLED.ipynb Yideng Master
1.5 03_Maths_plot.ipynbI draw, I draw
1.6 04_Face DetectionOpenCV
1.7 05_camera_detector camera recognition OpenCV
1.8 06_oled12864display
1.9 Enter the terminal command line and log in via ssh : root ; 1950
1.10 Configure Wi-Fi wireless network
root@ist:/# sudo su
root@ist:/# nmtui
1. Edit connection → enable connection
1.11 Built-in cases and games (to be improved)
Choose one of the cases below as a guide for getting started.
1. Top 10 Command Line Games For Linux
sudo apt install bastet Tetris
sudo apt-get install nsnake greedy snake
2. Interesting command lines of Linux
    https://zhuanlan.zhihu.com/p/128057151
https://www.cnblogs.com/hgmyz/p/12351022.html
https://blog.csdn.net/sinat_38682860/article/details/103056558
40 Super Fun Linux Command Line Easter Eggs and Games
https://blog.csdn.net/qq_32523587/article/details/84960304
2. Teaching and research activities
3. A Case Study in People’s Education Compulsory Course
sudo apt update
sudo apt install python3-pandas python3-sklearn git
pip3 install wordcloud jieba itchat pyfirmata siot
3.1Physique test
3.2 Find prime numbers
3.3 Water consumption
3.4 GDP statistics
4. mosquitto Internet of Things
https://www.jianshu.com/p/37f7ee7ead65
An open source message broker software that implements the message push protocol MQTT v3.1 , provides lightweight, supports publishable / subscribeable message push mode, and makes short message communication between devices simple, such as now Low-power sensors are widely used in mobile devices such as mobile phones, embedded computers, and microcontrollers.
4.1Introduce mosquitto warehouse and update
#Note that this step cannot be ignored
sudo apt-add-repository ppa:mosquitto-dev/mosquitto-ppa
sudo apt-get update
4.2 Execute the following command to install the mosquitto package
sudo apt-get install mosquitto
4.3 Install mosquitto development package
sudo apt-get install mosquitto-dev
4.4 Install mosquitto client
sudo apt-get install mosquitto-clients
4.5 Check whether mosquitto is running correctly
sudo service mosquitto status
status running results:
4.6 Local testing
#Open a terminal and execute the following command to subscribe to the topic "mqtt"
mosquitto_sub -h localhost -t "mqtt" -v
#Open another terminal and publish messages to the topic "mqtt"
mosquitto_pub -h localhost -t "mqtt" -m "Hello MQTT"
#Now you will see the message being displayed on the previous terminal .
4.7 Network Test ( test.mosquitto.org )
#Through the following command, you can schedule all test mqtt information to be released to the official website. Of course, others can also subscribe to the information you publish.
mosquitto_sub -h test.mosquitto.org -t "#" -v
#You can also publish your own exclusive information under the official mqtt service
mosquitto_sub -h test.mosquitto.org -t "myxyz123" -v
#Subscribe to your own information
mosquitto_pub -h test.mosquitto.org -t "myxyz123" -m "hello mqtt"
test.mosquitto.org supports encrypted and unencrypted MQTT message modes, and also supports using TCP or Websocket as a bearer. Different packet formats can be observed through wireshark packet capture .
Attachment: Win driver installation
The usb rndis driver under Win will be recognized as a COM port by default, and the driver needs to be updated manually.
1. First download kindle_rndis.inf_amd64-v1.0.0.1 , http://www.qudong51.net/qudong/540.html ;
2. Then run the fifth cmd file as administrator ;
3. Double-click the COM port recognized by the USB serial port in the device manager and search for the driver on the computer, that is, download the unzipped folder;
4. Wait for the installation of the RNDIS driver in the network adapter to be completed.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 07:31:46
