tpLdE
EspHarbor
This is a desktop assistant based on Esp32 and provides USB Hub function, which not only solves the awkwardness of placing a small display on the desktop alone, but also greatly solves the problem of insufficient USB ports.
This project is divided into two parts:
1. Based on ESP32, desktop information part.
2. Based on the USB part of FE8.1. [click to enter]
principle:
  The principle of this project is actually very simple. FE8.1 provides four USB2.0 outputs, so I led out three of them as USB Hubs, and the last one was connected to the ESP module through the serial port chip CH340C to make a simple desktop information board.
But because of the actual structure, this project requires two projects, which are the ESP32 part. USB Hub part [click to enter]
Test Firmware Arduino Configuration
Notice:
1. This firmware uses part of the code related to the ESP8266 desktop small TV, which is just an auxiliary test (because I am still in the exploratory stage of the code and am not sure when it will be completed)
2. Automatically configure WIFI for SnailNotes
3. Currently there is only one function to display the time
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 04:31:40
  • Has anyone made a learning remote control using 430?
  • Send data through serial port! Lost? !
  • uPyCraft IDE now supports microbit
  • Looking for wince development information based on 6410
  • The control system of stepper motor composed of DSP and PBL3717A
  • How to add hard interrupt to DSP/BIO in DM6437
