ghaytweyhtoo
UV deep ultraviolet LED 18650 battery holder version
Safety warning, please do not look directly at the UV lamp at work, it will cause damage to your eyes! ! !
Let me complain in advance [dog head saves life]
  • The cost is a bit higher than 100 million
  • The efficiency is too low
  • It’s better to use quartz UV lamp
Some remarks
  • For explanations of principles such as constant current dimming, please refer to the notes on the schematic diagram.
  • The maximum brightness current exceeds 1A, please pay attention to the battery’s discharge rate.
  • 3D printing shell in production
  • Lamp beads are very expensive. I bought them for free.
  • If you don't want to use UV LED, you can replace it with other ordinary lamps for lighting. Just modify the current sampling resistor of the constant current circuit.
  • No need to add supports to the shell
  • V1.31 Correct the resistance value of the constant current drive circuit
Hardware description
  • Extremely advanced typec interface
  • Dual-band UVLED, UVA&UVC
  • Constant current drive and dimmable
  • Use a potentiometer to simultaneously control dimming, switch constant current chip, and fan
  • Onboard 18650 battery holder, integrated charge and discharge overcurrent protection, using 4056 chip for charging
  • Standby current 0.308ma, working power 0.68W-4W
shortcoming
  • Because there is no aluminum base plate, the heat dissipation is relatively poor. The heat generated at the highest brightness may be too high to dissipate, but there is a fan interface.
Material link
Comparison of the sterilization principles of UV-A and UV-C
UV-A oxidation changes properties
●Photosensitive molecules such as riboflavin and porphyrin in bacterial cells can absorb specific light energy in UV-A
●Bacterial cells are oxidized to form active molecules such as OH-, O2-, O2, etc.
●The cell wall of bacterial cells is damaged and thus killed
UV-C directly damages DNA
●DNA in bacterial nucleic acid is exposed to UV-C light
●Bacterial DNA bases are broken and the DNA structure is destroyed
●Bacterial cells are killed and cannot reproduce
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 07:37:33
