smallembedded
Magic button v1.1 version
There have been no updates since version 1.0 was released.
I always feel a bit regretful and there is still a lot of room for improvement.
It's time to release version 1.1. It's easier to solder. They are all single-sided components and are limited to personal play.
The code needs to modify the pin definition based on 1.0
♥♥♥♥♥♥     If you like it, move your little hands and like it, thank you orz    ♥♥♥♥♥♥
The video is too large, please see:
https://www.bilibili.com/video/BV1S3411g7tz/
Overview:
  1. Materials use 3D printing + acrylic
  2. The shell of the button retains the original design and adds an acrylic + frame structure.
  3. PCB circuit + mechanical structure redesigned, the structure has stabilized
  4. Optimize power consumption standby
  5. Add expansion pins to facilitate adding external sensor modules
  6. The battery is 402025, about 150mAh
  7. Support Kaihua low shaft
  8. 4 countersunk head screws M1.0x8, 4 hex nuts M1.0, M1.2 are also supported.
  9. OLED supports two types of screens on the market, 28P (ssd1315) and 16P welding (ssd1306)
  10. Add 6-axis sensor to increase compatibility and facilitate purchase
Production:
PCB
Composed of 3 PCBs 0.8mm thick:
  1. btn
  2. display_xxxx
  3. mcu_xxxxx
The ones in the preferred box are basically the same as version 1.0
3D printed structural parts
Four structural parts need to be printed. It is recommended to use light-curing printing. You can place an order at 3D Monkey:
  1. Bottom cover (choose material, such as white resin, which can transmit light)
  2. Pressure plate
  3. Overall shell
  4. Acrylic shell (panel printing needs to be done separately in Lichuang Mall)
  5. Transparent shell ( choose one of 4 and 5 )
panel
If you choose item 4 in 3D printing, you need to print the panel
Requirements are as follows:
  1. Acrylic
  2. 1.5mm thick
  3. Adhesive
  4. Transparent (black translucent optional)
Accessories
Screw: M1.0 or M1.2 countersunk head, depth 6-8mm
Nut: M1.0 or M1.2, hexagonal nut
software
Notice:
If you are using the nrf52 version of PCB, you need a JLINK downloader (supports SWD) to download the code.
NRF52 version
  • Install VScode
  • Install platformIO
  • Install Nordic nRF52 platform, version 9.4.0
  • Burn Bootloader, the file is in .platformiopackagesframework-arduinoadafruitnrf52 ootloaderpca10056
  • Compile and download source code
Physical map
3D printing of a three-dimensional monkey, UTR 6180 material . The light green one is nice
renderings
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 11:17:00
  • LaunchPadFirmwareUpdater2.0
  • Getting Started with LPC54100
  • What does your ideal team look like?
  • Intelligent tracking car
  • The Huaqing Yuanjian Download Center has some great products! Come and have a look~~~
  • 2016 Spring Festival-Homesickness
