aerobotics
ESP32 Photovoltaic MPPT step-down synchronous rectification [ADS1115]
Foreign open source handling https://www.instructables.com/DIY-1kW-MPPT-Solar-Charge-Controller/
This project is modified from Gggggg's Lichuang version esp32 mppt - Jialichuang EDA open source hardware platform https://oshwhub.com/gggggg/esp32-1kw-mppt_copy
V4.1 This version has wrong buttons. You need to cut off one of the fixed feet of each of the 4 buttons.
V4.2 Fixed button problem 20220722
Modification content:
Old habit, remove some USB-ttl circuits and change to direct ttl interface
Remove a dcdc 3.3v circuit and use LDO to convert 5v to 3.3v
LCD power supply changed to 5V
Discuss with each other QQ:483012638
MPPT perturbation algorithm with CC- CV
80V , 30A input (solar, wind turbine, PSU )
50V , 35A output (lithium-ion, LifePO4 , lead-acid, etc.)
98% peak conversion efficiency (synchronous buck)
WiFi and Bluetooth Blynk Phone App Telemetry
Charger /PSU mode (can operate as programmable buck converter)
16 -bit /12- bit precision ADC measurement (ADS1115/ADS1015)
Automatic ACS712-30A current sensor calibration
Battery and Input Disconnect Recovery Protection Protocol
LCD menu interface (with settings and 4 display layouts)
Flash memory (non-volatile setting saving function)
Setable PWM resolution ( 16bit-8bit )
Programmable PWM switching frequency (1.2kHz - 312kHz)
Power capability:
12V output / battery - 420W @35A
24V output / battery - 840W @35A
36V output / battery - 1000W @35A ( 1260W when safe unlocked )
48V output / battery - 1000W @35A ( 1680W when safe unlocked )
A friend has already done version 4.1 and helped find some problems and corrected them in 4.2pcb.
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-06 15:53:31
