newrudeman
NRF52840 Dongle
Lead out the configuration resistor to facilitate serial number modification
There is also a burning pin for easy burning.
Modified using nRF52840 official design drawings
If necessary, you can replace the TypeC interface with A port~
About firmware
Attached here is the firmware of IndexHMD,
When using the Index firmware, you need to modify the configuration resistor to P0.24/P1.3/P1.4 (the Index firmware can short any one of the three) (the default onboard ones are P0.02, P0.04 and P0. 06).
If not short-circuited, it will be recognized as "Valve VR Radio & HMD Mic" instead of "Valve VR Radio". The former will include a microphone input.
About packages and components
CAPC1005X04L is C0402
32.768kHz does not need to be installed
120R/0.85A is a magnetic bead. In fact, it can be short-circuited directly (
The antenna can be replaced by another one, but you need to pay attention to modify the grounding (the antenna used now is a monopole, and the other side does not need to be grounded)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 02:42:20
