aerobotics
[Schrödinger’s Rabbit Paper] Steering gear tester based on STM8
I have the following three major purposes in drawing PCB:
1. [Cuteness is too big]: It means that the size of the PCB should be as small as possible
2. [Obsessive-compulsive disorder friendly]: Align and align! If not aligned, you will die!
3. [The Stubbornness of 0805]: I am blind and only solder devices above 0805 (the
design goal is to make a smaller ESC tester that can be directly plugged into other boards with pin headers and
comes with its own LDO. Accepts 3.3~6V input.
The minimum output is 988us, the maximum is 2010us, and the cycle is 20ms.
See the attachment for PCB project files.
Circuit diagram preview.
PCB wiring.
PCB front and back sides. 3D preview.
PCB physical picture.
Poorly written code. Preview
actual output effect (minimum & maximum)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 22:10:04
