aytwartoofyoroo
[Training Camp] A four-legged robot dog developed based on the open source Hongmeng operating system
Product introduction required by the topic: It is developed based on the OpenHarmony open source Hongmeng system. The chip used is hi3861, which supports 16-channel servo control, GPIO, ADC, PWM and other operations. The mechanical dog has been realized to move forward, backward, turn left, turn right, and lie down. Inferior functions, reinforcement learning will be supported later. (mpu6050 needs to be expanded) Question analysis chip solution: Multi-channel steering gear control board based on HiSilicon Hi3861 chip and PCA9685 Overall design scheme block diagram of I2C communication circuit between Hi3861 chip and PCA9685Screenshot 2022-07-18 180504.png
IMG_3090.mp4
HiBurn.exe
Robot dog firmware.bin
Dog Engineering Drawing 2.DXF
Engineering drawing of dog.DXF
BOM download
PCB_PCB_[Training Camp] Four-Legged Dog_2022-09-23.pdf
PCB_PCB_[Training Camp] Four-Legged Dog_2022-09-23.json
PCB_[Training Camp] Four-Legged Dog_2022-09-23.pcbdoc
Gerber_PCB_【Training Camp】Four-Legged Dog.zip
Schematic_[Training Camp] A four-legged robot dog developed based on the open source Hongmeng operating system_2022-09-23.pdf
SCH_[Training Camp] Four-legged robot dog developed based on the open source Hongmeng operating system_2022-09-23.json
Sheet_1_2022-09-23.schdoc
61795
Summer Training Camp Power Meter
Introduction: A real-time display power meter developed based on N32G430C8L7
The question requires
a real-time display power meter developed based on N32G430C8L7.
Question Analysis
We know that power cannot be measured directly. We know that P=I*V. So we can measure the current and voltage to indirectly get the power value.
IMG_3240.mp4
BOM download
PCB_PCB_#The 7th Lichuang Electric Competition#My first entry_2022-09-23.pdf
PCB_PCB_#The 7th Lichuang Electric Competition#My first entry_2022-09-23.json
PCB_#The 7th Lichuang Electric Competition#My first entry_2022-09-23.pcbdoc
Gerber_PCB_#The 7th Lichuang Electric Competition#My first entry.zip
Schematic_Summer Training Camp Power Meter_2022-09-23.pdf
SCH_Summer Training Camp Power Meter_2022-09-23.json
61796
8254
Introduction: 4-string lithium battery protection board
4 string lithium battery protection board
BOM download
PCB_PCB_8254_2022-09-23.pdf
PCB_PCB_8254_2022-09-23.json
PCB_8254_2022-09-23.pcbdoc
Gerber_PCB_8254_2022-09-23.zip
Schematic_8254_2022-09-23.pdf
SCH_8254_2022-09-23.json
FM8254 four-string lithium battery protection board_2022-09-23.schdoc
61797
[Internet of Things] Hongmeng Light Turning Magic Device for the Internet of Things
Introduction: A light-turning artifact made using Hongmeng hi3861
Light turning tool made using Hongmeng hi3861
80C3E2D0DFA52EFA41F908DB0565B175.mp4
BOM download
PCB_PCB_Board_2022-09-23.pdf
PCB_PCB_Board_2022-09-23.json
PCB_Board_2022-09-23.pcbdoc
Gerber_PCB_board.zip
Schematic_[Internet of Things] Internet of Things Hongmeng Light Turning Magic Device_2022-09-23.pdf
SCH_[Internet of Things] Internet of Things Hongmeng Light Turning Magic Device_2022-09-23.json
Hongmeng switch +1315930A_2022-09-23.schdoc
61798
Genshin Impact 15CM ruler
Introduction: Modified based on the open source project of Lichuang Open Source Platform, adding a protractor, the measuring range of the ruler is 14cm, and the graduation value is 1mm.
Original project: https://oshwhub.com/Lxd15/genshinimpact
ruler front
Gerber_PCB .zip
hk4e_zh-cn.ttf
BOM download
PCB_PCB original god_2022-09-23.pdf
PCB_PCB original god_2022-09-23.json
PCB Original God_2022-09-23.pcbdoc
Gerber_PCB original god.zip
61799
(Unfinished) Nixie tube Pomodoro clock (under construction...)
Introduction: Dual IN12 Nixie tube Pomodoro clock based on W600 (WiFi module) + RT-Thread (RTOS) + SU-03T (offline voice module). The software only completes project creation.
In the early stage, we planned
two IN12 nixie tubes with decimal points, which are pluggable and easy to replace if they break.
Dual TYPE-C direct plug power supply, can be plugged in from the back or side.
To support WIFI time synchronization, it is tentatively planned to use the domestic Lianshengde Microelectronics chip W600 as the main control, and RT-Thread-4.1.0 is selected as the RTOS.
It supports self-propelled power-down time. We tentatively choose the domestic SD3078 from Shenzhen Xingweifan Electronics, ±3.8PPM, with an error of 2 minutes per year at normal temperature and 10 minutes per year at wide temperature.
Consider adding an offline voice module (off-the-shelf module, estimated cost 20) to communicate with the main control and display the time via voice control. The model has not been selected yet (SU-20T or 03T with smart movement). This firmware upgrade is achieved through serial port forwarding or directly using TYPE-C. There must be a pin to control the power off of the voice module, and connect it to ch432.
Add external FLASH (the internal one is also enough, the module Flash should be 2M), use FlashDB to record the number of Pomodoros, how long the Pomodoro lasted, how many were invalidated, etc.
Passive buzzer prompt.
CH423 expansion chip + high voltage transistor to drive Nixie tube.
QMI8658-IMU is used to realize rotation adjustment timing and detect vibration. Place the phone under the Pomodoro Timer. After starting the timing, if there is a movement to pick up the phone, the timing will be reset.
Come to a touch button.
If there is an automatic download circuit, you can use the official downloader of Xingtong Zhilian to download directly through the serial port.
To know the current ambient temperature and humidity, use AHT20-F from Aosong Electronics. Humidity accuracy: ±2%RH (25℃), temperature accuracy: ±0.3℃.
Because the firmware upgrade serial port and communication serial port of SU-03T are the same, the communication line needs to be disconnected during the voice module upgrade, and it can also be powered independently. The voice module has an independent power supply switch. Consider using two USB-to-serial ports, one for w601. To the voice module, when the voice module needs to be upgraded, use another serial port console to send commands to the w600 to power off the voice module and switch the serial port line.
Follow-up. . . . . . . (under construction)
61800
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 05:30:27
