P1sYG
GYJ-0008_Wide voltage four-digit digital tube display module code tube display module
****[Brief description]************
****Function description:**********
****The function of this industrial grade board is,****** * Used to display four-digit digital tube values. The input low level is a valid signal. It can be connected to programmable devices such as microcontrollers, PLCs, and industrial control boards. The input voltage range is wide, and the digital tube is a dynamic scanning display. ******** Board size : 72mm
long Features:          1. The input adopts terminal screw crimping.          2. Four-digit digital tube dynamic scanning display.          3. Wide working voltage range 5~36V.          4. The input port can be directly connected to the IO port of the microcontroller without a driver.          5. Stable operation and low power consumption.          6. The input voltage terminal has an anti-reverse connection function, and the board will not be burned if the power supply is connected reversely.          7. It can be installed on the DIN rail in conjunction with the 72MM card slot plate.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 20:40:25
