zOlGHKwuH
#The7thLiChuangElectricityContest#USB voltage and current meter
Note: * is a required field,
please fill it in during the registration stage↓
* 1.
Please enter the content of the project function introduction...
Measure the voltage and current of USB output
Note: The topic is not limited, it can be a solution to a problem in life/work, a solution designed for a certain group of people/scene, a graduation project/course design/DIY project/purely cool project, etc. Mainly talk about what problem you solved by what means.
*2.
Please enter the content of the project attributes...
wu
Note: Please indicate whether the project is publicly disclosed for the first time; whether the project is original; whether the project has won awards in other competitions, if so, please describe the details of the award; whether the project has participated in the defense at school.
* 3.
Please enter the content of the open source agreement...
Note: Altruism is self-interest, please read the following content carefully.
Embrace open source and give unlimited value to the project. It is recommended that more than 80% of the core functions of the project be open source;
if a part of the function is irreplaceable and the project cannot solve the corresponding problem after deleting it, then the function implemented by this part is the core function of the project; for example, if an electronic load is designed and a host computer software is designed to monitor power changes, the electronic load is the core function and the host computer software is an auxiliary function; for example, an isolated 485 module is used in the electronic load to communicate with the host computer, then the communication function implemented by this 485 module is an auxiliary function;
the project should choose an open source protocol that suits it. If the project references other open source projects, the source should be indicated and the original author's open source protocol should be followed; the original project is recommended to use the GPL3.0 open source protocol;
the functions directly referenced from the original circuit or original code of the open source project cannot be used as the core functions of your own project, and the functions directly implemented using the general modules on the market cannot be used as the core functions of your own project.
Please fill in the following in the competition stage↓
*4. Please enter the content for the hardware part
Note: It is recommended to use Jiali Chuang EDA. If you choose other EDA tools, please upload the schematic diagram in PDF format, the PCB drawing in PDF format, and the PCB file in Gerber format in the attachment. Here you can explain in detail the implementation principle and mechanism of your project, precautions, debugging methods, testing methods, etc. It is recommended to introduce your ideas to others in the form of pictures and texts.
*5.
Please enter the content of the software part...
Note: If your project involves software development, please upload the corresponding engineering source code in the attachment. Here you can explain in detail your software flow chart, functional module block diagram, explanation or popular science of related algorithms, source code structure, compilation environment construction and configuration, source code compilation method, program burning method, etc. It is recommended to introduce your ideas to others in the form of pictures and texts.
*6.
Please enter the content of the BOM list...
Note: The BOM list involved in the project. Please upload a screenshot of the BOM in this position. Please upload the list details in the attachment in PDF format. It is recommended to include model, brand, name, package, procurement channel, purpose, etc. The specific content and form should be based on the clear expression of the project composition.
*7. For the competition LOGO verification,
please upload a project picture containing the competition logo, and the logo is printed on the PCB in the form of silk screen.
Click zip to download the competition logo! (Contest logo).zip
* 8. Demonstrate your project and record it into a video and upload it.
For some reason, the oled does not display
the project verification failure.
More details: https://diy.szlcsc.com/posts/d76d9cb41705430e9a54e7a5feed07a5
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-03 01:18:54
