fish001
SC8802
Function parameters of SC8802 buck-boost power module solution verification board
● Buck-boost charging management control potentiometer to adjust the output voltage VBAT: 1.22~30V/12A
● Reverse buck-boost discharge output voltage potentiometer adjustment VBUS: 1.21~30V/12A
● Supports separate current limiting for input and output ports (CC mode), adjustable resistor to set current limiting value
● Adjustable switching frequency: 200kHz to 600kHz, can be adjusted by replacing different resistors
● PD fast charging power supply: maximum support for decoy 20V/5A 100W power supply independent power supply Recommended VIN: 7~24V
● Charge and discharge mode: different modes can be switched by toggle switch
● Adjustable input and output current limit, bilateral output short-circuit protection, under-voltage protection, over-voltage protection, over-temperature protection
● This module has not undergone any Professional testing and improvement Use with caution
● PCB parameters RF4 material 2-layer board size 60*30*1.6mm Component parameters are subject to the schematic.
Note: When switching the charge and discharge mode, be sure to cut off the power or the chip may be burned.
Note: This Under certain conditions, the module may have problems such as chip burnout or MOS burnout. Please refer to the following. Reproduction is not recommended.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-07 22:31:22
  • An interesting question QQ chat
  • ADI identifies fakes and pinouts
  • Is this true? Most people who buy Apple phones are "invisible poor people"
  • Single chip perpetual calendar
  • Request LM3S8962 Evaluation Board
  • PIC microcontroller PWM module
