3228
The smallest on the entire network!! WiFi killer ESP-01 wifi killer
WiFi Killer based on ESP-01
WiFikiller is only used to test network security, and must not be used to attack other people's networks!
The module can be flashed with ESP-01 or 01S
and the firmware can be soldered to the board. The lithium battery can
be charged with TP4059.
I don't have it on hand. Welding a 4059 to a 4054 can also use
3.3v for power supply, using AMS1117.
In addition,
one SMD LED,
one 10k resistor,
one 5.1k resistor,
four 10uf capacitors
(the above are all 0402 specifications),
one Type-C
OK, that's it. First
, attach the module to the writer and connect it to the computer.
Unzip the ESP8266 Flasher.zip.
After setting it according to the picture, select the port where the module is located and click Flash to start writing the firmware. The firmware comes from the Internet. Please explore and experience it by yourself
after writing it. After powering on
and finding the WiFi connection named Wi-PWN,
open the browser 192.168.4.1 and enter the background.
After making sure that the firmware is OK, you can solder it to the board and play with it.
You can buy a small lithium battery online. Remember to bring a protective plate.
It is recommended to solder the battery first and then esp01,
sandwich the battery in the middle, and then put a drop of 502 between the battery and esp01.
Do not use hot melt glue, it will heat up when working and charging
. In addition, you can change the color of the LED light by yourself.
ESP-01 has less color than 01S. There are two pull-up resistors, but the firmware has been written, so don’t worry about it.
ESP-01S has a controllable light, which can be set in the background whether to turn on the light when working.
ESP-01 has a power light and a comm . light, this light will flash during communication.
For this project, I prefer to use ESP-01. Change the power light to ice blue, change the comm light to green, and put the original blue comm light into the charging indicator. This way on the light
, you can clearly tell whether it is on or off, and the comm light flashes when it is working, which is actually quite cool)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 05:07:45
