走马观花
24V to 5V power module
This module has the same size as the AC to DC module on the Internet and can be welded to the circuit board using a vertical plug-in method. Can be used in different power supply scenarios.
Parameters of this module:
1. Input voltage: 3.2-35V.
2. Fixed output 5V.
3. Output current: rated current 1A, maximum 3A (heat sink required). If the output power is greater than 15W, it is recommended to add a heat sink.
4. Conversion efficiency: up to 92%.
5. Static power consumption is only about 3mA.
6. Since it is a buck module, in order to ensure output stability, please maintain a minimum voltage difference of 1.5V.
7. It is recommended to use current within 2.5A for long-term work.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-03 13:01:35
